Previous in Forum: Internal Combustion Engines   Next in Forum: Calculating Fan Run-Down Time
Towers - Mechanical Parts and Functions
01/23/2009 5:35 AM
Hello
Please what are mechanical parts of the tower and their functions ?
Thanks a lot
Engineering Fields - Mechanical Engineering - New Member Technical Fields - Technical Writing - New Member
Good Answers: 21
Re: Mechanical parts of the tower and their functions
01/23/2009 5:37 AM
Mechanical Parts of the Tower and their Functions
1. Feed Inlet Nozzles
These are used to direct the feed into the proper level of the tower in order to give the most efficient operation.
2. Trays
The trays are used to give maximum fluid contact inside the tower. This produces the most efficient end product.
3. Downcomers
The downcomers direct the fluid from one tray to the next lower tray in the tower.
4. Weirs
The weirs are "walls" which keep the correct level of liquid on each tray. The rising vapours must pass through the liquid on the trays. This gives good contact between the liquids and the vapours.
Look over to the next challenge
Good Answers: 61
Re: Towers - Mechanical Parts and Functions
01/23/2009 9:20 AM
Read this article:
http://www.pipingdesigners.com/Training%20-%20section%202c1.htm
Do it once and do it right
Register to Reply 2 comments
