Previous in Forum: Happy Spring Festival - Gongxi facái - Kung hei fat choi   Next in Forum: New Uses for Old Manufacturing Equipment?
8 comments
removing adhesive tape on aluminum
01/24/2009 5:47 AM
I have white aluminum window frames which has adhesive tape .
When I try to remove the tape the tape does not come of easily. It is difficult to remove the tape.
Can someone assist me with a solution?
Thank you
Re: removing adhesive tape on aluminum
01/24/2009 5:58 AM
Try using liquid lighter fuel! The stuff you put in Zippos!
01/24/2009 7:15 AM
You can also use nail polish remover or alcohol. There are other products but I don't know where you are,try a hardware store for adhesive removers.
CARPE CRUSTULORUM!
Good Answers: 266
01/24/2009 7:17 AM
Denatured alcohol
01/24/2009 8:15 AM
Would that be more like vodka or wine?
CARPE CRUSTULORUM!
Good Answers: 38
01/24/2009 8:38 AM
Goo B Gone works great even on old dried tape. We use it to clean sliders on audio boards that build up really bad. Techs love to tape notes on specific points for reference.
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
01/26/2009 1:53 PM
If by "White" aluminium you mean overcoat-painted aluminium, then be careful with plastic solvents, as these may also remove the overcoat-paint with the adhesive tape altogether.
If by "white" you meant non-anodised aluminium, then by all means use any plastic or rubber solvent, from Benzine to Acetone...
Good Answers: 25
01/28/2009 12:06 AM
Use either Afta Cleaning Fluid or K2r Spot Lifter. I use lighter fluid too.
Jon
01/28/2009 9:56 PM
Have you tried WD 40? It won't hurt the frames or leave residue or discoloration.
CARPE CRUSTULORUM!
charsley99 (1); kudukdweller9 (1); Mr. Truman Brain (1); not so smart (3); ozzb (1); Yuval (1)
