Previous in Forum: Tan Delta Testing   Next in Forum: Designing 11-kv Networks
Belgium - Member - New Member
Good Answers: 21
Permanent Magnet AC Motor
01/26/2009 11:08 AM
Hello,
I'm looking for a permanent magneet AC motor. A motor with permanent magnets on the rotor and a 3 phase winding in the stator. The motor has an output shaft power a proximaly from 1.0 - 2.2 kW. (rotor speed +/- 500 - 1000 RPM)
Does any body know who does produce such motors .
most regards.
Good Answers: 804
Re: Permanent Magnet AC Motor
01/26/2009 4:13 PM
In general, the only reason to have a permanent magnet AC motor is if it is Synchronous. If you do a search using that term, you will find plenty of references. Here is one:
Siemens SIEMOSYN permanent magnet synchronous motors
