Previous in Forum: Wind Turbine Blades Covered With Photovoltaic Cells?   Next in Forum: Corn Burner Linked to Furnace's Cold Air Return
Effluent Treatment plant
01/27/2009 1:14 AM
What is Primary, secondary & Tertiary treatment Plant?
Engineering Fields - Piping Design Engineering - New Member
Re: Effluent Treatment plant
01/27/2009 1:18 AM
Hi Are you talking in terms of Waste Water facilities? if so see the following....
They are used to treat wastewater before it enters another body or is reused. A wastewater treatment system performs several activities: preliminary treatment, primary treatment, secondary treatment, tertiary treatment, and sludge treatment. During preliminary treatment, screens are used to remove large, solid inorganic materials such as paper and plastic. During primary treatment, the wastewater passes through a sedimentation tank to remove smaller, solid organic materials using a gravity settling process. During the secondary treatment stage, an activated sludge process uses submersible mixers to break down any dissolved or suspended organic solids. This is followed by the tertiary treatment stage in which disinfectants, usually chlorine, are mixed into the water to eliminate harmful microbes. Finally, during the sludge treatment stage, the collected sludge is processed for reuse.
Hope this helps.
Brent
01/29/2009 1:03 AM
WE ALWAYS THINK OF HIGH TECHNOLOGY AREA WITH LARGE INVESTMENT...EFFLUENT TREATMENT CAN BE MADE WITH SIMPLE BIOGAS OR GOBAR GAS PLANTS...IT WILL GIVE US CLEAN ENERGY AND SLURRY AS MANURE...BY TREATING THE SLURRY FURTHER IN VERMI PIT WE WILL GET VERMI COMPOST FOR ORGANIC AGRICULTURE...FERTILIZER LOBBY AND PESTICIDE LOBBY MAY OPPOSE FOR MASS SCALE IMPLEMENTATION BUT THIS IS ONE OF THE CHEAPER AND HEALTHIER OPTION...IN INDIA TO LIMITED EXTENT WE SUCCEDED...
G. K. GHOSH
United States - Member - New Member Technical Fields - Technical Writing - New Member Popular Science - Weaponology - Organizer Hobbies - Target Shooting - New Member Engineering Fields - Nuclear Engineering - New Member
01/27/2009 8:44 AM
Check out this Wikipedia entry for the basics, too.
Good Answers: 101
01/28/2009 9:12 PM
Assuming you're referring to a WWTP, primary means sedimetation of solids, secondary means biological or chemical, depending on the nature of the waste, and tertiary means final polishing before discharge.
Anonymous Poster (1); BRENT (1); DVader1000 (1); Steve Melito (1)
