Previous in Forum: valve pressure rating   Next in Forum: Drive-End Bearing Heats Up
how does a spiral wound gasket works
01/27/2009 2:08 AM
guys can someone please tell me how does a spiral wound gasket works.
Good Answers: 103
Re: how does a spiral wound gasket works
01/27/2009 2:44 AM
01/27/2009 3:28 AM
sir
can you tell me how these spiral wound gaskets are manufactured ,
the processes and machines used to manufacture these gaskets
01/30/2009 9:02 AM
Hello. i don't understand all of this. Can anyone give me more light on all of this
Mohammed_isleem8@yahoo.com
Engineering Fields - Piping Design Engineering - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 27
01/31/2009 11:49 AM
Simple: As load is applied (as the bolts are tightened) the gasket windings compress to fill the voids and irregularities of the sealing surfaces. The filler winding allows greater ability to fill such irregularities than would a single sheet of gasket material (consider a mattress with individually-contained springs rather than interlocked-springs. The former conforms better to the shape of your body). Inner and outer rings (if incorporated) prevent extrusion and help to locate the gasket.
Best regards, HeviiGuy
01/27/2009 3:27 AM
sir
the processes and machines used to manufacture these gaskets .
Anonymous Poster (3); BoltIntegrity (1); sb (1)
