Hi
My question is simple but not easy.I need help from you guys.
I want to joint 2 types of welding neck flange RF with FF, I know code B31.3 it's not permitted. Even if it doesn't fall under a code requirement.
even in case someone suggest to remove the rasid face also I can't do it becuase of operation (fluid is flammble).
Material is ASTM 105 ASME B16.5 with size 3"
2 solution I got from my friends
1- use adapter ring.
2- make a 1/16" thk steel ring plate equal to the height of the raised face and to cover the area outside the bolt hole on the raised flange. So, it makes like a flat face flange.
but really I am confused.
Any other Ideas please.
