I want to determine the IR intensity using an IR-detector, I don't want to use this detector as a switch (using a transistor). I want some levels, even if it was in mV, to compare with in my micro.
Example: - If the detector is facing the IR diode, it gives high level( 200 mV)
- If the detector is making an angle with the IR diode, it gives lower level(100 mV).
thank you
