Previous in Forum: Connecting a Generator in Parallel   Next in Forum: Canadian Electric Code - Underground Installation
Differential Protection
01/29/2009 10:21 AM
Dear all,
I'm commissioning Micom 632 differential protection with DRTS secondary injection, and have problem regarding the I restraint. According to the manual, I restraint of the relay is ([I1]-[12])/2, while the DRTS only has choices for:
  • ([I1] + [I2])
  • ([I1] + [I2])/2
  • ([I1] + [I2])/3
  • Max (I1, I2)
  • Min (I1, I2)
  • (I1*I1)^0.5
  • Max (I1*I2)/1.732
  • (I1+I2)/2
What should I choose? Or the DRTS can not be used to test the relay?
"I know less than all, but more than many who know less"
Pathfinder Tags: Differential Protection
Re: Differential Protection
01/29/2009 3:02 PM
I restraint is internal computation in the relay.
For testing the relay, you need to do the following :
Inject current on primary side ( 3 currents)
Inject the same on secondary side.
You have to set up current as per the actual transformer arrangement ( ratio and phase displacement ) in order to :
=> verify stability of the relay (no trip is all 6 currents are within the limit)
=> test tripping ( when 6 current are not in line, so that you simulate fault in-zone)
Hope this help you.
BR.
01/30/2009 7:58 AM
Thx for the response,
I want to use the menu from the DRTS as it can provide the complete graph (m1, m2, etc). Does it mean that I can only test it with manual procedure as you described?
Regards.
01/29/2009 9:07 PM
does in your DRTS have Phase shifter adjusment? I think when you inject current, you must make each of phase oin I1 and I2 differ 180 degree. it will represent 11 - 12.
Regards
02/01/2009 4:03 AM
What is the final aim of your test :
=> checking CT are properly wired ?
=> TRIP loop checking ?
=> Alarm annunciator testing ?
=> cheching the complete characteristic of the relay ?
As tou said commissioning, I assume you are testing the relay on site, prior to energisation.
In such case, testing the full caracteristic is not what should be done .
you should focus on :
- CT wiring ( i.e stability)
- tripping loop
BR.
02/18/2009 3:48 AM
Dear BR,
All but most important aim is check functionality of relay according to setting.
So after testing we should insure about relay operation if any thing happen wrong.
ya, I am agree with you but these all point all important only in installation time.
adhyartha (1); Anonymous Poster (3); rita.triani (1)
