I have read some of the grey water forums. I have several statements and questions for feed back.
what I am going to do is water my plants ( I have a lage yard)
History
my wife does laundry 3 times a day, famialy of 5 all showers, guest house (shower only)
plumbed for gray water, showers guset house shower, laundry
I have 2 thoughts 1 is to have the water dispursed once used and filtered to plants, so any time a shower or laundry is used it is on (slump pump) the problem is I have six zones and timming for each zone and time of day (summer is really hot, =more water=more of the time)
ther other way is to get a holding tank (say 250gal above ground) but my next problem is activating a pump and timer (unless off the same timer) for all the zones.
If I run out of grey water, how to back up with fresh? (directly into tank? a pool leveler in tank to activate fresh? and of course contamination (don't want that)
system
so here it is what I think I have figured out, I have 2 to 4 pipes (showers, laundry)
going into a 55 gal tank (could be smaller) with a screen filter (like a pool removable fine mesh)that the water pours into before going to the bottom. Next a slump pump is activated (option one) to tie to garden water lines (submirged heads to plants) or (option 2) the water is pumped into a tank (above ground) to be held until water time and then disbursed to zones. like I said the problem for me is pump to timer to zones to fresh water back up (unless I have 500 gal tank)
Let me know your thoughts , I look foward to the replyies! thanks scott woodward
