Previous in Forum: Machining time   Next in Forum: Tire Pressure
43 comments
Good Answers: 52
Should You Warm Up Your Car Before Driving It?
01/30/2009 12:23 PM
I have noticed that where I work it seems most people get in their car start it and and go. It seems as if from the time they get to their car to the time they start pulling out is no more than 15 seconds. As its winter here it's quite cold and I imagine they want to get moving quickly so the car warms up quick so they don't have to sit in a cold car.
I have always felt that you should let your car warm up a little, at least 30 seconds to a few minutes to get the oil circulating, before driving.
I am not talking about getting the car warm for comfort, that is a different issue, this is only about car life and emissions.
So I have three questions relating to this.
  1. In terms of car life and engine life, should you let your car warm up in the winter and if so how long is appropriate?
  2. In terms of being green, should you let your car warm up in the winter? Keep in mind possible effects of car life extension, or efficiency of the car in open loop vs warmed up closed loop mode when being driven.
  3. Overall is it better to let your car warm up if so how long, and what effect does outside temperature and age of the car play. How to these answers change in the summer?
Re: Should you warm up your car before driving?
01/30/2009 1:17 PM
From the BMW 328is owners manual :"Do not allow the engine to warm up while parked; instead, start driving immediately at a moderate engine speed".
They say this because prolonged idling can damage the catalytic converter.
Idling is not the most efficient way to warm up the engine. Nor is it environment-friendly. The best way is to get going applying light load, i.e. no flooring until the engine reaches its nominal temperature.
Start the car and let the engine run with the car parked until the engine idle drops down to the 800 rpm territory. Then drive slowly for about 1 - 2 miles. After the 1 - 2 mile point, normal driving. The initial high revs are programmed in to get the catalyst up to operating temperature as quickly as practical; so I let the catalyst get happy and then driving slowly for 1 - 2 miles gets the rest of the engine 'warmed up'.
Charlie don't surf.
01/30/2009 1:30 PM
The owners manual from my Land Rover Discovery, and the one from the Range Rover states the same thing. Wait for the idle speed to drop and off you go, keep your foot light until the needle moves on the instrument panel. Worries about engine wear? Change to synthetic oils.
Re: Should You Warm Up Your Car Before Driving It?
01/30/2009 1:52 PM
Click and Clack recommend a warm-up period of "no more than a minute or two".
After that you're just wasting gas.
Do drive conservatively for the first few minutes, too. That's my recommendation.
01/30/2009 2:18 PM
My rule is to never pull away before the engine has started.
The concept of warming it up is complete hogwash...the engine is still running, the pistons are going up and down, the oil is circulating, it doesn't much care if it's connected to the wheels via the gearbox.
Ok I s'pose I'll reluctantly concede that if you immediately tried to drag a loaded skip uphill, it may put a slightly greater strain on the engine... but even then it's the first few seconds turning over with no oil pressure which would cause more harm.
Yes it's bollocks a fallacy in terms of engine care...different if you need to generate some warm air for your paws or to defrost/demist the windscreen.
It's a car for pity's sake ..it's there for your convenience not vice versa..stop petting and cleaning the damn thing...rant over.
01/31/2009 4:40 AM
Your words are the voice of my heart...
Aged man is not old man...
01/30/2009 2:48 PM
In virtually every "modern" (i.e., post-1950) automotive engine, the oil is circulating throughout the engine within three to four seconds at the very most. (barring 50-weight oil in that old Studebaker up in Nome..)
Start it, put it in gear, and drive off. Easy the first mile or so, as suggested. Just have the oil recommended by the manufacturer, relative to your locale, in the engine and you'll be fine.
"For a successful technology, reality must take precedence over public relations, for Nature can not be fooled." - Richard Feynman
The Engineer
Good Answers: 129
01/30/2009 4:12 PM
It depends on the car. Cars 10 years or older might benefit from a little warm up. I think anything younger you can just start and go, as long as you don't gun it. Also, I wouldn't define a day as "cold" for your car (thus requiring warming up) unless the temperature is below 25 Farenheit.
Hobbies - Car Customizing - New Member
Good Answers: 11
01/31/2009 12:36 AM
Current advice is no warm-up.
Since the 80's cars have been using thinner oil, which pumps faster at lower temps.
Most cars will use a 5w-30 at the heaviest, with some at 0w-20.
If you start the car, then fasten the belts, you should be ready to go.
Idling prolongs the warm-up, resulting in more condensation in the oil, as well as more fuel dilution, also in the oil. The cats also will not light up at idle either.
You also use a significant amount of fuel during a warm-up.
I'm in Wisconsin, and I haven't been warming up, even in a '77 Olds at -10F.
Though I went to 5w-40 synthetic.
01/31/2009 1:43 AM
Greetings.
If I remember correctly 90% of engine wear is in the first 10 seconds of operation.
Therefore either have an electric oil pump installed to bring the oil up to pressure in the whole system before starting or let the engine run for about 30 seconds so that oil gets to all the engine. Don't rev up a newly started engine.
Use a good synthetic oil in everything (engine, transmission, transfer case, differentials, and lubing). I use AMSOIL and don't sell it.
Some commercial equipment won't start until the oil pressure comes up to full pressure with an electric oil pump. This is an engineered design to prolong equipment life.
01/31/2009 6:06 AM
Agree w/ all said to date.
In addition to pumping up pressure before starting, pre-heating the contents of the sump & the engine + coolant can work wonders. Operating dimensions at startup, & reduced condensation, right from time zero.
Using waste heat from an inefficient mode of operation is rather poor.
If you always do what you've always done, You'll always get what you've always had!
02/02/2009 11:00 AM
Me side valve nut too. 1952 KR flattrack Harley
02/02/2009 5:55 PM
Cool! Currently Ford hotrod, & B&S race motors.
01/31/2009 8:57 AM
Another reason to change over to synthetic lube (oil). Most folks don't care what the end result is of no warm up. Time is money. Fuel injection has made this easy and engine wear is traded away (never by a used car) without a thought. At least the new lubes will hold down (remember the commercial) engine wear at startup.
Good Answers: 16
01/31/2009 9:13 AM
The days of letting the engine warm up went away with the sophisticated fuel injection systems being used today.
Remember always having to screw with the choke, flooding every now and then, etc
I guess these probably guys here now that have never had to rebuild a carburetor on the kitchen table???
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
01/31/2009 2:24 PM
Back in the 70's and early 80's, I had a side business rebuilding and setting up carburetors for mussel cars, (mostly Holly double pumpers). Talk about a useless skill today!
I had one of these:
Ya, with the 302
Setting up a Holly, through the entire RPM range, was more of a black art than science.
I still get a call once in a while to set one up, but no thank-you.
Fuel injection is light years ahead of any carburetor.
So many people have remote starters today. Push the button, the car is waiting for you all warmed up, with the heater cranking. It's all about having heat when you jump in.
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
Good Answers: 16
01/31/2009 5:33 PM
Reallllll nice. It didnt like cold starts did it???
United States - Member - U.S.A. Hobbies - Fishing - New Member
02/02/2009 4:59 PM
Possum's ain't aloud to drive, when have mussel's been able to do so?
There are always others less fortunate than you, be happy, to them you are Mr. Jones.
02/02/2009 6:04 PM
Hey, possum, just clam up, huh?
01/31/2009 9:26 AM
Some one told me long time ago, that rather than idling for a long time to get the engine warmed-up, it is better to start driving at a low speed (After allowing to idle for about 30 seconds so that the cylinder walls and crank bearings are coated with oil). Increase your speed as the engine gets warmed up.
01/31/2009 9:53 AM
You should start your engine and rev it to about 2000 rpm to splash oil onto the cylinder walls to provide lubrication to the rings and as soon as the oil pressure is up drive off with moderate acceleration.
People warm cars up so they don't have to get in a cold car or scrape the frost off the windshield.
01/31/2009 9:58 AM
I don't know, I thought putting the saddle on the horse was as far as I could go to warm her up but if there is something else...
CARPE CRUSTULORUM!
Good Answers: 196
02/01/2009 12:45 AM
Most of you who posted answers have no idea what you are talking about. The only real credible information posted so far is what has been transcribed from specific vehicle manuals; and it tends to be vehicle specific based on variables such as specific lube oils, design bearing clearances, level of oil filtration used by a specific engine and change intervals as well as issues of possible catalytic converter stress and fuel efficiency.
The relative influence of these factors has changed in recent years as the introduction of cat. converters, then fuel injection, then widespread availability of fuel injection, better engine machining practices, the lower viscosity synthetic oils and lastly the 2004-2008 EPA mandated reduction of gasoline sulfur content by 10 or more times.
Nowadays with low sulfur gasoline if you run a multi-viscosity oil of a viscosity range that is what the driver's manual recommends and you have a modern engine with fuel injection and a computer engine management all you need is about 5-10 seconds for the oil to get circulating and the oil light go out and then you are good to go as heavy on the accelerator as you can afford. Or if you want your car heater to get the car get as comfy as you need it and the defroster working well then leave it running till you settle behind the wheel. All it will cost you is gas and normal engine wear just like you were driving.
Back in the very old days before multiviscosity oils there was some good reason to let the engine warm up before loading it. You wanted the engine oil actually to get circulating and 90w oil in the stick shift transmission thin enough for the synchros to work. It was a habit we got into even after we didn't need it with the advent of multiviscosity oils, automatic transmissions and automatic chokes.
In 1939 an SAE paper was published showing that the wear of piston rings was related to water jacket temperatures. It pretty much stopped above 140 degF in the test engines of that time. Future studies pinned down the prime culprit. It was sulphur based acids that formed in liquid water condensed on the cold cylinder walls from water vapor byproducts of the combustion process. Once the temperature around the rings got high enough to get rid of the liquid water then the wear stopped.
As piston ring technology and oil properties improved over the decades the startup ring wear became less of an issue and taking the sulfur out of the fuel finished it off a few years ago. So warming up the engine isn't buying you anything in engine longevity these days. But I would say it really buys you something in cold winter weather. It's very important to get the defrosters working so you can see out of the windshield without it fogging up.
This all holds for most if not all modern passenger car and light truck gasoline engines that remain at factory specs. High performance and race car engines are a different story which I won't get into here. So are industrial engines. It all depends on the oil you use, engine's internal clearances and how precisely it is machined at the factory.
One other thing. About oil leaking out of the engine clearances back into the crankcase. This is nonsense. It simply doesn't happen unless bearing clearances are worn out of spec. The only "leakage" is the gradual collapse of hydraulic lifters as the valve springs push oil out of their clearances. Modern engines that are past their breakin (which happens pretty fast) can run at idle upwards of a minute or more with no oil in the oil pan before the oil heats from friction and thins out enough to damage the mating parts. The rattling you sometimes hear in an engine when it first starts is more a natural sound of moving and lubricated parts that quickly gets dampened out when they get submerged in a thick film of pumped oil.
Ed Weldon
Good Answers: 16
02/01/2009 1:29 AM
This is ones own opinion, open for interpretation and there are many of these. Regardless of the oil, the engines simply would not run well until they had warmed up due to the lack of proper mixture or fuel injection.
There are other posters that say rev the engine to X RPM's. This is already programed into the equipment these days.
You can over engineer or over think it all you like, but with an open mind you will see it all changed with fuel injection.
02/01/2009 3:02 PM
As soon as the oil pressure is up to normal in any weather , you should drive of, treating the engine as if it is brand new.....do not let it idle, do not let it rev high, do not let it labour.[Losts of good reasons!]
If you really want your engine to last for ever......Add about 250ml of engine oil or 500ml of diesel to a normal tank-full of petrol...this is neccessary if you do short trips....on the long run, the engine should get enough piston ring lub through the engine beathing system from oil-gassing.[Engine starts easier, even uses less gas!][Common sence
This little amoumt of oil will do no harm to the catalitic exhaust system and the exhaust system will last 3x longer.
02/01/2009 10:34 PM
At 315,000 plus miles I wait for the oil pressure to come up and I go. Car manufactures have their own motivations and parts sales are one of their biggest incomes so I take a lot of what they say with a grain of salt.
The extra fuel/ RPMs are either time out or sensor dependant. You probably can't get 100% power right off the start until the brain box/computer finishes its start up loop.
During the startup loop, emissions are not a priority of the manufacture.
As for wear: valves, cams, rings are film oiled. unless the engine has set for a prolonged time the film will be sufficient for startup and a little more; The main bearings and cam bearings need more than a residual film to handle the pressures involved with high torque and high RPM. Once oil pressure is up they are fine.
One counter point is if you get a dry lobe on a cam you wear a very thin hardened surface in very little time. Many a cam is lost from rebuilding and not pre oiling the engine before startup.
Brad
Good Answers: 196
02/02/2009 3:58 AM
U V -- All good points except on the oil draining issue.
I've taken apart stock engines with empty crankcases that haven't run in 20 or 30 years and there was still enough oil in the bearing clearances, cam lobes and even the cylinder walls to provide good enough lubrication to start up. The problems I see that are that often they need a little help building compression with a bit of oil in each cylinder, but not so much that it makes a mess of the spark plugs.
The other point is that if such an engine is a valuable high performance engine with heavy valve spring loadings I'd want to pull the oil pan, check the insides, put some prelube grease on the cam lobes and a give a few hand turns of the crank watching the valve action for signs of distress.
Ed Weldon
02/02/2009 1:20 PM
Very true Ed,
The thing I find is most modern engines fall under a high performance of the 70's, at least in part. Valve loading and RPM was much lower in the early 80's and before. Materials have made large improvements in output and design tolerances.
I have changed worn tappets in a 67 strait 6 with out to much worry about the cam. Something I would have to do some serious checking before attempting in a new engine.
On the other hand modern oils have much better properties. The cheap ones would need to be changed right away if they sat in an engine for a long time. The Additive package would be a coating in the pan and the base viscosity index is not very good. The additives will still settle out of the better oils over time but base oil is a much better lubricant.
Brad
Good Answers: 196
02/02/2009 2:08 PM
I seem to remember there were some GM engines back in the 60's and 70's, mostly V8 small blocks that had problems with cam wear. IIRC the 30-30 Duntov cams of the "60's" were not in that category.
Ed Weldon
02/10/2009 4:23 PM
Ed,
Are you aware if the '67 283 V8 small block fell into that category? I have one that I'll be rebuilding this spring.
I would rather be ashes than dust...
Good Answers: 196
02/10/2009 9:56 PM
VMI1998 --
I'm not an expert on chevy smallblocks; so I don't have exact info. My memory seems to lean in the direction of this being a 305/350 problem that was corrected within the warranty in a lot of cases. Maybe dig around for an old book on modifying Chevrolet V-8's. Lots was written on the subject back in the 1970's. A bit of ebay checking might turn up some cheap books on the subject. I would expect knowledgeable authors in that period to address the subject I raised with some real expertise.
The real test of your engine, especially if it has more than 50K miles on it (in other words, if there was much of a ring wear ridge on the cylinders) is whether there is measurable wear on the lifter wear pattern. If there is only a visible pattern with nothing you can feel with your fingernail (on the lifters) then go ahead and use the cam as it is. I can't remember if the 2 barrel 283's in 1967 had hydraulic lifters. If they did you may want to replace them with new if decent quality new lifters are available.
If it's a flat tappet cam and the lifters look good as well as the dimensional check on the cam and cam bearings is OK, then just go ahead and use the old stuff. Use a good prelube grease on the cam lobes when you put it back together.
Ed Weldon
02/11/2009 5:34 AM
VMI 1998: I believe this string if failures was due to a new surface treatment, gone bad. Also believe Ed W's recollection of victims & timeframe to be about right
To the best of my knowledge, aftermarket cams + lifters did not suffer this.
To add to Ed W's comments: if you re-use the lifters + cam, make double extra sure that each lifter rides on the same lobe it grew-up with. Already mixed? Replace!
Any reputable aftermarket grinder should be able to supply any profile you'll ever desire. Remember, though, too agressive a profile will spoil the fun. Work with their staff to select the right one.
02/11/2009 8:35 AM
Thanks guys! I appreciate the insight and I'll follow your advice.
02/11/2009 10:22 AM
You must have had cams ground. Mass production CAN really suck. We had a lot of failures in Honda Motorcycles in the 70's. Rockers really were as much of a problem as the hardness of the cam.
02/02/2009 4:57 AM
G'day frankd20, you've received some good advice hear, take it. The only thing I can add is remember your oil pressure is at its lowest at idle. Gentle driving will bring this up to normal and will warm you car up quicker too.
RRV
Fans of Old Computers - PDP 11 - New Member
Location: In a mushroom field somewhere in Canada. Kept in the dark and fed sh--, well you know.
02/02/2009 9:01 AM
Get a house with a garage. Problem solved.
Dirt is for vegetables. Pavement is for racing.
02/02/2009 9:26 AM
One thing for sure, the greeniest thing to do to heat up your engine when it is very cold (-20°C and lower) is to use an electric block heater for about an hour before starting the engine.
02/02/2009 10:15 AM
Electricity does not magically appear at the wall socket. It is either produced hydroelectrically by flooding a whole lot of wildlife habitat or by nuclear with a great deal of radioactive waste or by coal-fired plants. No need to discuss the harmful effects to the planet with coal-fired is there?
Yes, please plug your car in at night this is very green and helpful for the environment.
UFG
Good Answers: 16
02/02/2009 10:30 AM
So I guess you have a "green" garage that keeps your stuff warm then????
Good Answers: 196
02/11/2009 10:33 AM
Quote Tim: "So I guess you have a "green" garage that keeps your stuff warm then????"
YES!! HOT IDEA! 12x24x10 reinforced concrete box garage inside a manure pile. Just make sure the car windows stay closed.
That's not a bad smell, Son. That's the smell of money.
Ed Weldon
02/02/2009 10:48 AM
Let me know when you get snow in Mexico and then you can make fun of me.
Good Answers: 16
02/02/2009 12:22 PM
LOL fair enough... But I wasnt always so lucky, many of nasty winters in Baltimore
Hobbies - Fishing - Zoomer
02/02/2009 11:05 AM
One important safety consideration has been missing in all the discussions I've read about whether it is best to warm up a car in cold weather. Years ago, my father-in-law started his car after working 2nd shift on a cold winter evening (-15 to -20 F). He let it warm up a few minutes, then pulled onto the highway. As he went up a steep winding hill with deep ditches, the windshield suddenly frosted over. The frost inside the air ducts suddenly melted and the moisture was immediately deposited onto the inside of the sub-freezing windshield. He couldn't see a thing and went down the deep ditch, totaled the car, broke his neck, and nearly died. He eventually recovered.
I live on a highway with a posted speed limit of 55 mph, so traffic usually travels 60-70 mph. When I pull onto the highway, unless it's early Sunday morning or after midnight, I usually have to step on the accelerator hard to keep from being hit. I have also had my windshield suddenly frost over when the temperature outside was cold, -10 to -30 F, if I didn't let the vehicle warm up adequately first.
For the vast majority of modern vehicles in most circumstances, it is probably not necessary to warm up the vehicle to prevent damage. But in certain circumstances, like temperatures below -10 or -15 F and having to pull out directly onto a busy highway, warming up the vehicle can prevent catastrophic results, including total destruction of the vehicle and severe injury, or even death.
When in doubt, do it the right way.
Good Answers: 16
02/02/2009 12:35 PM
So it appears to me the overall best thing to do, (If you live in a very cold climate). Would be to install a block heater and keep your vehicle protected in a garage if you can...
  1. Obvious mechanical reasons.
  2. Comfort (quick heat).
  3. Safety, sort of goes hand in hand with 1 & 2.
Register to Reply 43 comments
Anonymous Poster (2); Bayes (1); Bricktop (1); Ed Weldon (5); Jim at GodwinPumps (1); jmart23 (1); JohnDG (1); jurie sa (1); lyn (1); not so smart (1); OlympiaWA (1); possum (1); Qqberci (1); ray cockrell (3); rrvau (1); sidevalveguru (3); stevem (1); Tim in Mexico (6); U V (2); unclefastguy (3); user-deleted-1105 (1); VMI1998 (2); Yosemit3 (1); zodiac (1); Zoomer (1)
