Previous in Forum: Pump Head Calculation   Next in Forum: API/5L-A PIPE MATERIAL
all about pump
01/31/2009 2:39 AM
Hello sir,
pls clarify the doubt.....the pump with rated spec is running in a plant....if i want to decrease the flow rate...whether i have to trim the impeller size or i could change the motor...............or connecting tubing of min dia in delivery side..pls clarify this sir..
Regards,
Mechanical engineer
Re: all about pump
01/31/2009 5:48 AM
If you are talking about a centrifugal pump then all you have to do is restrict the discharge. Put in a restrictor or lock a discharge valve in a required position.
Regards JD.
Good Answers: 266
Re: all about pump
01/31/2009 10:44 AM
Or you could install an AC adj frequency drive on the motor. Using it to adjust the motor RPM for the flow desired.
Restricting the output side of the pump will increase the pressure at the pump. Which will increase motor load and pump wear. If I was to do it this way I would plumb a bypass line with valve from the output to he suction side. With the two valves one to adjust system flow the bypass to control pump pressure.
Good Answers: 58
Re: all about pump
01/31/2009 11:31 PM
Ozzb,
Restricting the pump discharge will not increase the load on the motor. "Bypass" is a waste of energy and should only be considered if a minimum flow is required.
Re: all about pump
02/03/2009 2:48 AM
Dear Guest,
You have options:
1)Close a little the shut-off valve (discharge)- waste of energy.
2)Buy a frequency inverter - cost of device + cable + cabinet + programming of FI
3)Trim the impeller - one way.
My opinion : check the working point. Think about place on the diagram when you want to be and choose 1 or 2 or 3.
The diagram can be find on the producer internet site.
Important : If you will see the diagram you will realise that you cannot have lesser flow without changes of the pressure/head of the pump.
Remember to keep your pump as close to the highest efficiency.
jdretired (1); ozzb (1); SAMSAM (1); The Prof (1)
