Previous in Forum: Electrical Linear Actuator   Next in Forum: NEMA 5-15 / 5-20 plug end
Fanuc Control 0i Series and Alpha i Series
02/02/2009 7:03 AM
hello!
I have been facing one problem for last few months and didn't get the solution yet can any body help me.
My problem is,we have 5 to 6 cnc machine which has fanuc control ,when we run the nc program by memory card or external memory than automatically in between program exection ,the dash happened on the job.
and same program run smoothly after reseting the machine.
i have checked all the parameters,checked the programm,checked the offset,reference,every thing but could not find the answer.
If some body knows plz help me out
Thank you
Good Answers: 50
Re: Fanuc Control 0i Series and Alpha i Series
02/02/2009 11:47 PM
Your second paragraph (the one that asks the question) doesn't seem to make much sense. Could you try rewording your question, and restate what the problem is.
Good luck-
02/03/2009 1:39 AM
Thanks You Vermine for reply and i m sorry if u didn't get the question
Actually the problem is , During the execution of NC programm ,some times in between, spindle dashes the job.or I can say control system skip some blocks and execute the different block which is not in the sequence.This is not happening continuosly ,periodically it is happening .Same program runs after reseting without changing.
Register to Reply 2 comments
