Previous in Forum: Laplace Transform and Complex Variable "s"   Next in Forum: Steam-Jacketed Pipes and Steam Traps
Branch Connections and Pad Requirements
02/02/2009 11:39 PM
Branch connections can be reinforced or unreinforced stub-in/out with or
without pad requirement . How can one decide the pad requirement for
Stub- in / out branch connections ? Is there any Thumb rule or by
calculations only .
Thanks
Be simple and specific for a great success in Life
Good Answers: 51
Re: Branch Connections and Pad Requirements
02/03/2009 8:59 PM
Calculation only.
A little knowledge is a dangerous thing.
02/03/2009 11:26 PM
What code are you designing to?
02/04/2009 12:50 AM
Depend on which code used in design. If there is no definite code, I prefer using of ASME B31.3.
Note. With respect to thread by sachin_rastogi_in, the branch connection can be stup-in or stup-on (not Stub- in / out).
02/04/2009 2:32 AM
Sorry for spelling, the correct is: "stub-in or stub-on (not Stub- in / out)".
02/04/2009 1:19 AM
Use ASME B31.3 304.3 "Branch Connection" unless a different code is required.
Hope this helps.
Also the correct notation is "stub-in" or "stub-on"
Hobbies - DIY Welding - pipewelder
02/04/2009 3:53 PM
It is according to what specification you are piping to. If you look into ASME B31.1 or B31.3 they will have tables to show you when you should use a reinforcement pad and how big it should be. We have our own in-house Specifications that list the branch chart for which ever spec. we are using. Take for example steam piping where the spec. only allows a tee or weld-o-let type branch compared to a water pipe spec. will allow for a stub in type branch.
pipewelder
Register to Reply 6 comments
Abdel Halim Galala (2); pipewelder (1); Stewie (2); XMech (1)
