Previous in Forum: Maintenance: March drive motor size to pump size   Next in Forum: Petrol Engines as Powerful as Diesel Engines?
Setting of timing of diesel engine
11/02/2006 5:28 AM
Hi,
It will be highly appriciated if anybody can provide some info on setting of timing of CUMMINS model NHS-6-I / 743 engine and the availability of its injectors(PT injectors)
Thanks
Engineering Fields - Piping Design Engineering - New Member Technical Fields - Architecture - New Member
Re: Setting of timing of diesel engine
11/03/2006 1:46 AM
Hi
If you are located in india you can contact Ms/Powerica/Sudhier and co or (CDSS) Cummins diesel sales and service Pune Maharashtra India they will help you even if you are located outside india you can contact CDSS you can find their address on cummins india web site.Best of luck
Run silent run deep
Reply to Forum Thread
