Previous in Forum: Valves in PWR Nuclear Power Plants   Next in Forum: Spot-Welding Copper
ASME 16.34 Bolted Bonnet or Cover Joints
02/03/2009 12:13 PM
The formula calls for "Ag" (the area in sq. units of effective outside periphery of the gasket or o-ring)
What exactly does "outside periphery" mean? i.e. does it mean strcitly the "OD" of a ring gasket (regardless of the ID)? or should the area reflect OD minus ID?...What if the gasket were non-circular?
thanks
Bill
Re: ASME 16.34 Bolted Bonnet or Cover Joints
02/04/2009 9:35 AM
Bill-It is the Area within the OD of the Gasket. You do not subtract the area within the ID. Further, it does not include the centering ring for Spiral Wound Gaskets.
02/04/2009 1:23 PM
Thanks MechMark...I was leaning towards that. ... my analytical mind wants to tell me that "area" (for its definition in the traditional sense i.e. a flat nitrile ring gasket), is OD minus ID...
Thanks again!
Bill
Register to Reply 2 comments
You might be interested in: Metal Ring Seals, Gaskets and Gasketing, V-ring Seals
