Previous in Forum: Design Guidelines for Heat Exchangers   Next in Forum: Motors for Robotic Arms
Storage tank strength
02/04/2009 11:33 AM
Hi,
I've been searching for the formulae but can't quite find the ideal one. I want to be able to calculate the strength of an open ended vessel (open to atmosphers) that is holding water - effectively a water storage tank to check that the wall thickness in either acrylic or glass is thick enough, or if I need to add bracing at the top.
I have modelled it in SolidWorks along with the "water" and run through Cosmos for the loading, but I'm unsure it's correct. ie 1m dia x 1m tall cyliner 20mm wall thickness in acrylic, full of water - what would be my safety factor? I obviously know my weight of water but applying how this acts against the cylinder surfaces I need halp with, as it is not pressurised, only open to atmosphere.
Cheers in advance - Paul
Re: Storage tank strength
02/04/2009 12:50 PM
Hydrostatics & materials strength isn't my area - but just a thought: you haven't said where this is to be used - is there any danger of the water freezing?
Good Answers: 74
02/04/2009 7:59 PM
Neglecting rotational and radial restraint at the bottom, the stress of a cylindrical shell under hydrostatic pressure is a pure tension varying from 0 at the top to pr/2t at the bottom where p is the pressure, r is the radius and t is the thickness.
If you wish to calculate the bending moment at the bottom due to continuity with the bottom of the vessel, you would need to consult a book such as "Theory of Plates and Shells" by Timoshenko and Woinowsky-Krieger.
The safety factor depends on what you assume to be the strength of the material. For glass, it is quite variable. For acrylic, I have no idea what it is.
Bruce
Good Answers: 74
02/04/2009 8:31 PM
Sorry, the ring tension is pr/t, not pr/2t.
Bruce
Good Answers: 51
02/04/2009 9:36 PM
Ahhhhhhhh - The Great Timoshenko; I was going to suggest his work as well.
The exact solution that you are looking for is on page 486 (2nd Ed.) of "Theory of Plates and Shells" (one of the classics). It is much too involved to detail here - you should obtain a copy, perhaps from your local university library.
Note that bracing along the top edge is really only required for rectangular tanks, or open round tanks subject to wind, or closed tanks subject to pressure. If your tank is open to atmosphere and there are no other loadings, other than pure hydrostatic, such as wind or nozzles, then the upper edge should be fine (there is no pressure/force on the upper wall edge). Picture the bottom half of an hour glass if you will, that is the approximate shape the walls will try to form with the greatest displacement near the bottom). The problem area will be on the lower edge in accordance with Timoshenko's bending moment formula.
A little knowledge is a dangerous thing.
ba/ael (2); JohnDG (1); XMech (1)
