Previous in Forum: ANSI Code for Alloy Steel Pipes?   Next in Forum: Two-Way Valves and Three-Way Valves in HVAC Systems
Applying Oil to Sheet Metal Surfaces
02/05/2009 7:06 AM
I am designing a pick and place system for deep drawing system after picking the sheet metal component with suction cup. Afterwards I want to apply oil on the sheet metal surface , viscosity of the oil 150 cs, I need to apply at top and bottom surface of the plate also
Good Answers: 101
Re: Applying Oil to Sheet Metal Surfaces
02/05/2009 12:46 PM
And your question is?
02/06/2009 10:25 AM
Now that is the question.
02/06/2009 11:52 AM
Although missing I think I get the question.
Use a spray system to lube. G OOOO G L E Search (without a question mark)- there are many manufacturers of these systems.
If you have another question, consider using the "?" symbol (right bottom on most keyboards), it really simlifies things for the readers, google may not care, but we do!
Did I get this right or was it not a question---->?<-----
Mirco
02/16/2009 2:46 AM
both sprays and/or topbottom rollers can be used both generaly apply too much fluid so it is advisable to install a tray under the system to collect the ecsess which can then be returned back to the supply tank
several of these system i have installed if you want more info contact me direct
toscatsert@mynet.com
Register to Reply 4 comments
Janissaries (1); mircoconsultant (1); o?l care doctor (1); RVZ717 (1)
