Previous in Forum: valves   Next in Forum: Bending Radius for steel Pipe
Welding Filler Materials and Pre / Post Heat
02/05/2009 9:20 AM
I am welding ASTM A36 Carbon steel to ASTM A668 Class D. I need to know to filler material and Pre/Post heat. Thanks
Re: Welding Filler Materials and Pre / Post Heat
02/23/2009 4:49 PM
We are currently setting up a WPS for A36 to A668. Preheat and Postheat would be dictated by the material thickness. A668 is a forged form of AISI 4140 which would make it at the edge of "Low Alloy" steel regardless of class (F,K,etc.). Depending on the code/spec used, most 70XX-H4 (ie; E7018, E70S-6, etc.) fillers should work due to the A36 part of the weldment. Most of the failures we have seen are in the HAZ on the A668 part at or near the weld toe. Higher preheats would be recomended. You may want to ref. the Table of preheats in AWS D1.1.
Reply to Forum Thread
