Previous in Forum: car power lost   Next in Forum: Automobile - Maintenance Management System
1997 Ford Ranger - Ignition Won't Fire
02/06/2009 8:28 AM
I have a 1997 ford ranger 3.0 V6 automatic. The ignition isn't producing any fire to the plugs. All fuses are good. It may need a coil pack. But what else is in this system that can go bad to cause it not to fire. It is getting power to the common going to the coil, from the plug. And when plugged to the coil power goes out to the other 3 wires from the plug. I just wonder if this is right. Does the crank position sensor has anything to do with this.
If you are going to do something. Do it right or don't do it at all.
Good Answers: 25
Re: 1997 Ford Ranger - Ignition Won't Fire
02/06/2009 11:06 PM
The electronics inside the distributor, are likely the photo type of timing system. The light producing diode may be malfunctioning, or you may just have a little piece if grit or a metal fragment inside that is creating one wholly firestorm as the enerts spin wildly around. Or you may be having a "brain" malfunction.
likely though if you have current into the distributor cap and no energy coming out through the plug wires you have found your source of evil, it will be something going on with the distributor.
TMF
The only problem with common sense, is that not very many people have it, or know how or when to use it.
Good Answers: 123
02/07/2009 1:35 AM
You should do some more looking before shelling out your money. Is the distributer turning when the starter is engaged? Does it have a distributer? Did the Ranger die while driving, or just refuse to start one day? I would hate to see you buy a coil pack if your timing chain jumped. Can you check the compression?
Bob
02/09/2009 5:21 PM
HELLO
Here is the solution, look under the factory floor mat on the passenger side of the vehicle, you will see a plug in connector that has come loose. Reattach the two ends of the connector and tape them together. This is a common problem on that model vehicle.
02/13/2009 10:45 AM
Start with doing standard, no spark trouble shoot routine. Then come back at point where a fault cannot be eliminated. Asking for all possibilites is both time wasting and inefficient.
Register to Reply 4 comments
Anonymous Poster (2); bob c (1); Toomuchfun (1)
