Ok the truck is stock, and there are several issues that have come up all at the same time, hopefully related.
First issue is in ANY engaged gear, while stopped, the truck slowly loses rpms and then begins to choke and stall out. IF the shifter is put into Neutral or Park, it idles fine. I assumed the low idle adjustment rattled its way loose and checked it, it was as low as possible, so I raised it some. It now takes longer for the problem since the idle starts higher but it still only takes about 10-15 seconds at a light to stall out if left in gear. This symptom also COMES AND GOES in a single trip, one light to the next I don't know what it will do.
In addition, the truck has been abe to breeze up to 70-75 onthe highway while towing, and now it wont pass 70 FLOORED.
First thing I was told to check was fuel filter, did so and it was black as night, so I replaced it along with cleaning out my pre-filter screen of some debris. Stalling/idle problem still remains, towing I have not tested yet (they could be unrelated).
SINCE I have changed out the filter, I filled the canister and bled out the system at the injectors. There is a primer pump under the filter canister and when we pump it, it sounds as if air is comming out somewhere but I dont kow if thats a self bleeding pump or if there is a airleak (if so, it could be causing the idle problems)
Now, the truck seems to be shifting REALLY hard into and out of gears when I move from park/neutral into drive or reverse (I think this might be because the low idle is now too high). Under acceleration it also seems to shift just slightly rough. I also noticed for the 2nd time in 2 days that under decel/off throttle, I hear and feel a clunk (as if some tension was release) and the truck will not display the idle/stalling trouble at the next light. Once I've accelerated again and stop, it chugs again.
-history on transmission- it was rebuilt by AAMCO (on a trusted friend's advice, his good friend owned the shop) about 10,000 miles ago. they said it had been rebuilt before from what they saw, and in total the truck has 185k miles and I've owned it since 165k.
