Previous in Forum: Repairing Scroll Compressors   Next in Forum: ASTM and SA 351 CF8M
8 comments
Crane Brakes
02/09/2009 1:11 PM
I need some help even after doing an internet search and I thought the following was a very simple question.
What is the proper name for the brakes on an overhead crane that are used for the lifting rig?.
The crane is positioned and is not moving nor is it's gantry.
I was involved in a discussion with a HSE Officer and I was overwhelmed with the names used in industry.
Good Answers: 74
Re: Crane Brakes
02/09/2009 1:30 PM
Bruce
Re: Crane Brakes
02/10/2009 2:14 AM
Im an ole Canadian crane mechanic and we called them Friggen BRAKES !
When it comes to cranes , there is no name for most of the "stuff " we work with .?
Its a Black Art and full of mystery and very little government regulation or training for newbies .
The thing is that big stuff is used to lift things but no thought was put into the weakest point , the cable , and the Friggen BRAKES !
Dont worry , i haven seen a hoist yet that is not fail safe .
When is the last time you heard of a crane losing its load ???
What dosent kill you makes you stronger , lifes a trip so sit back and try to enjoy the nice scenery.
Re: Crane Brakes
02/10/2009 7:44 AM
I am not a mechanic, but have worked around them for years and was a rigger for an overhead factory crane back in the day.
I figure we have brakes to stop the trolley, the gantry, and the lift.
Listening to my HSE guru, it sounds like a War and Peace length novel has been written by OSHA describing the brakeing systems with several names included for each function.
Re: Crane Brakes
02/10/2009 6:15 AM
Normally it's called hydraulics thruster brakes.
Anand ck
Good Answers: 25
Re: Crane Brakes
02/10/2009 7:05 AM
There are different types of Brakes used for E.O.T Cranes such as Electro Magnetic Shoe Type Brake, in this brake there is solenoid type plunger which pulls the lever which in turn closes brake liners fitted on the brake drum shoes . Brake Drum is mounted on the motor shaft. Other is similar brake but lever is operated by electro hydraulic thruster and is called Electro Hydraulic Thruster Brake. This brake gives slow release of the brake so smooth starts and stops are achieved.
Re: Crane Brakes
02/10/2009 8:05 AM
I worked on a few cranes that used worm gears to drive the hoist. As You know the worm gear will turn the spur gear but not visa versa thus stopping the hoist in any position. My to cents worth.
oilcan13
Good Answers: 16
Re: Crane Brakes
02/10/2009 8:12 AM
Without knowing the drive type on your equipment, all anyone can do is speculate.
Re: Crane Brakes
11/29/2010 5:42 AM
Good post, we can call it lowrider Bicycle or Hydraulic Brake.
Thanks for sharing this.
Hoist Crane || Jib Crane
Register to Reply 8 comments
Anonymous Poster (1); ba/ael (1); kroni (1); machine head (1); oilcan13 (1); qaqcpipeman (1); suresh sharma (1); Tim in Mexico (1)
