Previous in Forum: PVC Pipes for Water and Sewage   Next in Forum: Speed Sensor for 1992 Lancer 1.8 Automatic
Automotive Glass Scanning
02/09/2009 3:02 PM
What is the used tool for the automotive glass scanning ? to make a drawing on the autocad for example.
Fans of Old Computers - PDP 11 - New Member
Location: In a mushroom field somewhere in Canada. Kept in the dark and fed sh--, well you know.
Re: Automotive Glass Scanning
02/10/2009 9:42 AM
You can use a non laser type tool like a FARO or you can use a laser type tool like HandyScan3D.
A FARO tool will give you a "cloud data" file, (lots of points that give the surface envelope of the glass) that you can later manipulate in a 3D software package like SolidWorks to produce a surface file.
A laser tool can give you a 3D surface file directly which you can bring into a 3D software package like SolidWorks and clean up.
UFG
Dirt is for vegetables. Pavement is for racing.
02/17/2009 8:24 AM
Dear sir,
good day and i hope that every thing is well with you
I see the tools you mentioned, on internet but i ask if there is some thing with lower cost, that give only a two dimension drawing not 3D as in my application we need only the 2D drawing for the sheet of glass
Register to Reply 2 comments
