Previous in Forum: Fuel Rates   Next in Forum: CNG compressor capacity
Submarine Hose Procedure Needed
11/03/2006 10:57 AM
I would like to know the procedure of crude oil submarine hoses testing.
Engineering Fields - Piping Design Engineering - New Member Technical Fields - Architecture - New Member
Re: Submarine Hose Procedure Needed
11/07/2006 6:57 AM
we were testing the components of submarine like pipes,hoses,and valves etc based on the depth in meters the submergence is designed for example our test depth was 250Mtrs we were testing all components to 30Kilogrms/Sqcms Hydrolyc or every 10meters of depth excerts 1Kilogram/sqCms you can work out your test pressure yourself.You need a pump to develop the test pressure.
Run silent run deep
You might be interested in: Hose Crimpers, Hose Reels, Hose Fittings
