Previous in Forum: Stepper Motor RPM   Next in Forum: Karaoke Recording Software
11 comments
ASTM A36 vs. JIS
02/10/2009 9:11 PM
Hello
I have a question regarding clients request.
Basically our client gave us specific spec for welding process, and they want it to be ASTM A36, meantime right now we are using JIS standard ( Japanese). How can I compare which JIS steel matchup to ASTM a36. Client is from America and wants American Standard.
Where can i find information regarding these type of steel. I need to make sure our JIS steels match with their specs..
Thank you
Good Answers: 51
Re: ASTM A36/JIS Question
02/10/2009 9:20 PM
I feel generous / like pushing the rules (copyrights)
You can download the A-36 standard here:
http://ifile.it/2hrv7fo
(you don't need to sign-up: simply click on "Request Download Ticket" in the top left corner, wait a couple seconds, then click on "Download")
A little knowledge is a dangerous thing.
02/10/2009 9:30 PM
Wow thanks for that! Appreciate it very much, so hard to find specs unless you pay.
Also regarding this, do you have any information on NDT( Nil Ductility Transformation Temperature)? Astm a36 has a temperature of 20 degrees F.
Thanks again for the file!
Good Answers: 51
02/10/2009 9:35 PM
No worries (I have since deleted the link though)
What is the intended use of the steel?
02/10/2009 9:38 PM
hey,
Well right now we are starting a project, making a stretcher for a huge Healthcare company, we are the manufactur. , Currently in Taiwan, they gave us specs for welding process. Our factory has welding machines and we are making sure we can match their specs. We use different Steel, JIS.
Do you have any information on JIS(Documents)? Also any docs on AISI/A2.4 (Standard Symbols for welding,brazing,nondestructive examination
Good Answers: 51
02/10/2009 9:48 PM
......... uhhhhhh ......... that is kind of pushing it (sharing more info), sorry.
However, you should refer to the applicable building/construction code regarding the nil ductility temperature.
02/12/2009 2:12 AM
That is kindda copyright voilation :D .. u are not supposed to share these things unless u believe in OpenSource Engineering concept..
Regards,
Xill
Good Answers: 19
02/12/2009 2:35 PM
Actually, this is across the line.
I too struggle with the issue of "overpaying" hundreds of $$$$$$ for various industry standards. I do try to get the information for the lowest cost possible.
But, if it is something that I will refer to again and again, I will find a way to bite the bullet and get my employer to pay the cost for the info needed.
IMHO, the first question was over the line but might have been ovelooked as a one time offense. The second and subsequent standards requests are pushing things too far. Cut it out!
02/12/2009 7:24 PM
YES i understand, please don't ban me, i won't be asking for any more standards...thanks
Good Answers: 19
02/13/2009 9:48 AM
I won't ban you. (Besides that's not my job here! ) Go whip yourself with a wet noodles 10 times before coming back to post and consider your sin forgiven. At least by me.
Seriously, we're all in this together to help each other out. Small pieces of information from standards is OK, but I would hate for someone to try to close this site down because of too much "Copyright infringement".
Good Answers: 51
02/13/2009 6:14 PM
Re: ASTM A36 vs. JIS
02/22/2009 8:32 AM
Hello Dear
I just checked my mail and saw your question. I am a machanical engineer from UET Lahore, Pakistan. When I was studying there, I have made a presentation at that time. And now I have found your question's answer in that. I am senging it to you. It having some more concerned information for you.
Take care
Regards
Umar Sharif
Type
American
British
China
DIN
Japan
Russia
Structural ASTM A36 BS4360/43A GB2005 DIN 17100 JIS G3101 Gost 380
Reinforcing ASTM A615 BS4449 GB1499 DIN488 JIS G3112 Gost 5781
Hot strips ASTM A569 BS1449 GB709 DIN 1016 JIS G3131 Gost 1050
Cold rolled ASTM A366 BS1449 GB708 DIN 1623 JIS G3141 Gost 9045
Galvanized ASTM A527 BS/EN10143 GB5066 DIN/EN10143 JIS G3302 Gost 14918
Register to Reply 11 comments
Anonymous Poster (2); luispl (3); Ried (2); XMech (4)
You might be interested in: Durometers, Thin Clients, Solder
