Previous in Forum: Recycling Wastewater from DM Plant   Next in Forum: new tecnology sand washing
Rubber bullet
02/11/2009 1:42 AM
A rubber bullet deforms momentarilly increasing the contact area (deform when contacting the wooden block) and thus reduce the impact per square area, while the aluminium bullet with the same momentum will retain its shape with the subsequent initial concentrated contact area (increasing in size as it penetrates the wooden block).
Therefore the aluminium bullet with the same diameter and momentum will also knock the block over but do an substantial amount of damage to the block than the rubber bullet.
Pathfinder Tags: Rubber bullet
Re: Rubber bullet
02/11/2009 2:23 AM
