Hi there,
I have a large switchboard (mains incomer = 1600A) with 7 feeder sections all feeding different items of plant.
Both the mains incomer and all 7 feeder units have power metering installed. I have 2 questions: 1) My electrician takes a KWHr reading weekly from each of the meters. When I add up the 7 meters they don't equate to the reading on the mains incomer. Am I doing something wrong? Can I add KWHr readings together, or should I be adding KVA as each feeder will have a different power factor?
2) One of the feeder units is for power factor correction. The meter shows a reading like any other, but do the power factor correction capacitors 'consume' electricity? I thought they only absorb the reactive power? Is this where the additon of all meters does not match up?
Your help would be appreciated.
Martin.
