Previous in Forum: Protection   Next in Forum: Motor Frequency
transformer oil filtration
02/14/2009 5:08 AM
how does vacuuming the transformer help in the filtration of transformer oil
Good Answers: 42
Re: transformer oil filtration
02/14/2009 6:44 AM
The transformer oil filtration units carry out vacuum dehydration operation for oil filtration to helps to remove dissolved air and entrained gasses by vacuuming .
02/15/2009 3:07 AM
To filter the transformer oil, it is necessary to vacuum the oil from the transformer into the filtration and drying equipment. This is done to remove carbon residue, moisture and gases mixed in the oil.
In one of our substations, a series of DGA (dissolved gas analysis) tests showed 'warning' readings on ethylene and methane gases. We had to do offline vacuum filtration for 3 days to bring the high readings to normal levels.
Patriotism is the last refuge of scoundrels
Register to Reply 2 comments
