Previous in Forum: Initials   Next in Forum: Reading from parallel port on windows xp
FEA (Finite Element Analysis)
11/05/2006 11:34 AM
Hi, I want to know if somebody is using the FEA capability of the Autodesk Inventor.
Is this capability good for stress analysis? And the mesh module? It is possible to simulate a mechanism with the relative motion between the parts? How about dinamic simulation?
I have to do a selection of a FEA software for a University where I am teaching. I know the Abaqus soft, which is very complete but very expensive, so I will appreciatte the experience of other people in this matter, not only the use for teaching but also for industrial use.
Thaks in advance
Gabriel, Buenos Aires, Argentina
Pathfinder Tags: FEA Finit Element Analysis
Re: FEA (Finite Element Analysis)
11/06/2006 2:08 PM
I would contact the FEA firms directly or scan their sites closely for university versions of their programs. Most FEA companies produce a size limited version of their software for a nominal fee. They reason, correctly, that the software learned in college will be used professionally when the students graduate.
I left software docs after too many years of writing fiction of varying degrees.
11/07/2006 5:51 AM
It may be worth looking on the website http://www.feainformation.com/ in spite of the excess baggage. Several of the programs can handle dynamic effects, and this can include thermal, mechanical and electrical interactions. My (limited) experience is of Ansys software.
11/07/2006 5:38 AM
Do not not about the capabilites of Autodesk and finite element analysis. Our finite element class used SAP 2000. It is a very good program that is also used by structural firms.
11/07/2006 4:58 PM
cosmosworks is an FEA tool within Solidworks 3D modeler. We used that at Wentworth Institute of technology. Good program and it comes with a student package version. Wenworth is a small school and if we can afford it, it must be reasonably priced. Either way, look for student versions of whatever program you want to use if you want a better price
11/07/2006 5:38 PM
I don't have that much skill in this business, but I can tell you
the following.
(1) Per Dr. Abed Khaskia, President, Mallett Technology (the
distributor and engineering support organization for ANSYS/Multiphysics),
it is possible to get a node-locked license for $5k. This license will
solve all problems (e. g., CFD Flotran), but with a limit of 8000 nodes
in the model. More expensive licenses are available having higher node
limits, up to "no limit" for $100k.
(2) I have a license of Autodesk Inventor Professional and I sustain the
annual maintenance subscription for it (which just today cost me
$1495.00 to renew). This license allows unlimited node models to
be submitted, but only to a PORTION of the ANSYS solver that is
built into Inventor (specifically quasi-static solids problems). I
apologize that I am not yet deeply enough "into" Inventor to know,
e. g., whether thermal expansion is also included. A couple of years
back I had the pleasure of a slew of courses under Abed Khaskia
and his associates, where in particular I got the (not guaranteed)
impression that "thermal expansion" is a built-in fact of solids, which
leads me to suspect that Inventor might allow temperature gradients.
(3) You probably have heard of this before, but I am now discovering
(by exploratory surgical-type learning-by-diddling) that Inventor has
a wealth of pre-formed mechanisms which have actual physical properties.
Example from two days ago: Helical coil spring, complete with axial
k-stiffness factor (and beautifully drawn, to my tastes).
Hopefully, you have been helped by this perspective of someone who needed
to find a learning package to keep alive knowledge which I will use as the basis
for my career when I am first eligible for CSRS retirement in approximately 3 years.
Raymond A. Byrnes, Jr.
B.S.E.E., M.S., Ph.D.
rabyrnesjr@gmail.com
11/07/2006 6:45 PM
Hi Raymond: I am Mechanical Engineer and teacher of Mechanism in the UBA (Universidad de Buenos Aires) and in UNLZ (Universidad de Lomas de Zamora). In the last there is a license of Inventor that I can use. By now, I am using a Student Edition of Abaqus (limited to 1000 nodes), which is one of the most powerfull FEA software.
I didn´t understand a part of your messagge with regards to "CSRS retirement".What mean that? Good news or bad...?
Regards.
Gabriel
gabriel.dasso@gmail.com
11/08/2006 9:23 AM
Hi ! how r u? i'm suggesting u one software named ANSYS, which is very good in meshing also on FEA . It is chip compare to other because our collage has for STUDENTS , so u can imagine it is chip also & very good in ANALYSIS.
Register to Reply 7 comments
Anonymous Poster (4); Gabriel (1); mrhippo2 (1); rabjrsmouth (1)
