Wonder if any expert in this forum can help...
A faciity I was working in has 4 numbers of end-suction 45 kW centrifugal pumps (in parallel) meant to feed a number of water-cooled chillers in the plant room. The water supply to the pumps comes from a series of cooling towers located in a remote location (not far away) with a head of approx. 20 ft to a main header near the pumps.
Question: I have discovered that any one time, only 3 pumps are pumping whereas the other one is "churning" water ie. no pumping action. This could be verified by isolating the valves etc. and the substantial heat generated on the pump delivery side; an indication of no-flow. Obviously, this is a sizing issue and I would have thought the water supply volume is insufficient to feed all the pumps. I needed to get more volume flow for the system; what could be the factors contributing to the pump "choking" problem? Will running another supply pipe from the cooling towers to the feed header help?
The pumps are relatively new, so the pumps should be in good condition. Appreciate any pointers...
