Previous in Forum: Wrappers: More Expensive than the Product Inside?   Next in Forum: The Faster the PC, the Slower the Response (if it Doesn't Hang Forever)
Nil-Ductility Transition (NDT) Temperature?
02/17/2009 8:45 PM
Hello members,
I'm trying to find the out the Nil-Ductility Transition (NDT) temperature for standard ASTM 1011, I know the NDT for A36 is 20 degrees NDT. Although I still don't understand that, can anyone help me ?
thanks!
Re: Nil-Ductility Transition (NDT) Temperature?
02/19/2009 10:39 AM
The best data for ductile brittle transition temperatures has been done for AISI steels and not ASTM steels. Personally I don't know the reason for this, I can only summize that since most Met Es are ASM members and ASM seems to prefer that nomenclature over ASTM's.
Anyway, can you give the exact chemical composition of your alloy for conversion? Otherwise if this is a trade secret I would say do the Charpy Impact testing yourself to determine the NDT since Charpy testing is a lot of fun. A good whack and the top half of the sample flies across the room. Mainly this proves that a good metallugist is just a glorified blacksmith with a calibrated hammer, but I suppose there is some good data in there too.
All this worldly wisdom was once the unamiable heresy of some wise man. -Thoreau
