Previous in Forum: Wanted: Abrasive Paper for Anodized Aluminum   Next in Forum: Pneumatic test
Pressure Testing a Transformer Tank
02/18/2009 5:13 AM
Can tank of corrugated win wall type of 1000kVA/22/0.4kV (IEC 60076) distribution transformer endures a pressure test of 0.5bar, duration:5h without any over - expanding or damage?
Corrugated fin wall: deepth:330mm, heighth:1100mm, total length:1200mm.
Are there standard test values of pressure for this kind of test of transformer tank?
Many thanks
Re: Pressure test of transfomer tank
02/18/2009 7:06 AM
0.5bar? negtive pressure?
joking? or are you going to write 0.5MPa?
Re: Pressure Testing a Transformer Tank
02/19/2009 8:30 AM
Transformers are pressure tested to ensure that they can withstand pressures in this range especially if they are inert gas blanketted , nitrogen in most cases .
Typical inert gas pressure can be 0.1 to 0.4 bars.
transformer s which are not inert gas blanketted normally operate at near atmospheric pressire because they will be invariably free-breathing , either to a conservator "bag" or to atmosphere. The free-breathing is required as the oil expand and contract with temperature.
Why , exactly, do you want to test the tank at 0.5 bars ( I assume gauge pressure ,, that is 0.5 bars above atmospheric which works out to be approx 7.5 psig) ?
Usually , the big question is whether the tank can withstand a vaccuum!!!!! And if it can , how much of a vaccuum.
Learn more, Do more , Be more
02/20/2009 1:46 AM
haha, you can laugh at me, i forget that oil should be at the vaccum station. sorry.
02/20/2009 12:10 PM
If you press it up quickly while it is energized you can do the extra "Lock-Out Test" also.
12/17/2009 11:38 PM
corrugated tank should be tested at 2.8 psi but it can withstand a pressure of 4.5 psi witout deformation.
Anonymous Poster (1); cnpower (2); djacob (1); Goodho (1)
