Previous in Forum: regarding transformer   Next in Forum: Maintaining pressure in HT cables
Transformers
02/18/2009 12:26 PM
HI There
Can anybody pls provide me with tranformer ratings (R + jXL) for the following MVA ratings 12MVA, 15MVA, 10MVA 20MVA all must be step downs preferrably 66/11kV or any but it must be stepped down to 11kV if u have a list or website that u can refer me to that will also be nice duz i struggle alot to find these stuff on the internet. thanks
Re: Transformers
02/18/2009 1:36 PM
What you are asking is not physically possible to answer, especially since transformers of this size are NOT an off-the-shelf item and hence the characteristics will vary depending on the design (and numerous other technical things I am not going to go into at the moment). Is this a homework question?
If you are seriously trying to locate and purchase a transformer go directly to the transformer manufactures or hire a consultant to generate a proper transformer technical specification (then send it to the transformer manufacturers).
Re: Transformers
02/18/2009 1:51 PM
Hi there
Thanks for your reply, I need just typical ratings, i am not designing anything just doing some calculations and simple simulations and therefore just want the results to be a little more actual than estimated values.
Re: Transformers
02/18/2009 2:25 PM
You can not do better than estimated without the transformer being built. If you have a worst case value that you want, then you need to specify that to the transfomer manufacturer. They can then test to make sure they are providing it. The manufacturer can not give an exact value on the transformer till it is built. I know, I have asked and got told that very same thing. So if you want a %Z of 5 then you have to specify it and the X/R ratio as well.
Joe the Electrical Contractor to the EOR, I know it was suppose to be in my base bid, but I still am going to submit a change order for it.
Re: Transformers
02/18/2009 2:37 PM
Hi there
Thanks for the info,
i just want the ratings for the existing transformers of the MVA that i have specified above just typical values.
Re: Transformers
02/18/2009 3:10 PM
About the best info you are going to find is on Square D's website. That is www.squared.com. I think that GE also improved their website to include more technical data. But they both will give the disclaimer about the above situations. Good luck
Re: Transformers
02/18/2009 3:27 PM
Thanks i will check them out now
Dhimbulukwa (3); Electron Plumber (2); jack of all trades (1)
