Previous in Forum: Carbon Removal From Solgel Products   Next in Forum: Fusing Glass to Cement in a Kiln
SA 516 Gr 70 instead of SA 105 as stiffner material
02/21/2009 3:41 AM
Can I use SA 516 Gr 70 as stiffner material in place of SA 105 in an application where temperature reaches at 400 c?
Good Answers: 51
Re: SA 516 Gr 70 instead of SA 105 as stiffner material
02/21/2009 4:08 AM
Please elaborate, because those are two different product forms:
  • SA516-70 is plate
  • SA105 is for piping forgings
Also, which code are you designing to?
Maximum temperatures:
  • Section I: 454 °C
  • Section III: 371 °C
  • Section VIII-1 & -2: 538 °C
And note that at 400 °C SA516-70 is within the creep range and possible prone to graphitization.
A little knowledge is a dangerous thing.
02/22/2009 1:46 AM
Dear XMech, you are right, and I like to add:
• ASME SA516 is carbon steel for pressure vessel plates, for moderate-and lower temperature service, where ASME SA515 is carbon steel for pressure vessel plates, for intermediate-and higher temperature service.
• For ASME SA105, I prefer to use another material for higher temperature service like as ASME SA182 for forged or rolled alloy and stainless steel pipe flanges, forged fittings, and valves and parts for high temperature service.
03/04/2009 12:38 AM
CS PLATE MATERIAL ASTM A 516 GRADE70 THE METULLURGICAL PROERTIES TENSILE STRENGTH, SHEAR STRENGTH AND YIELD STRENGTH IS REQUIRED TO CALCULATE FATIQUE / FAILURE OF SPHERE VESSEL
Abdel Halim Galala (1); Anonymous Poster (1); XMech (1)
