Previous in Forum: construction   Next in Forum: construction man-hour standards
Poly Eurathane paint
02/21/2009 5:57 AM
Hi,
Where can we use PU paint on Civil strucutres in Industries. Does it have any specification on the area of usage & any limitations of the same.
Re: Poly Eurathane paint
02/23/2009 11:35 AM
I'm a mechanical engineer and have worked with design of urethane dispensing machines. What i can tell you about urethane is that its great stuff with in certain applications. One use is auto mobile restoration, but you can only bond this to rusted scaly steel. It does not bond well to clean bare steel. secondly it is sensitive to UV light, it will start to brake down the chemical composition. Now this just an opion of mine, one would need to inquire about the use of urethane paints to a chemist for each application. One ther thing, some people are/can be allergic to the Urethane paint/material when they come in contact with it on the skin, it can cause a rash like situation.
03/21/2009 11:13 PM
Bassically polyurethane are topcoat paint, even if there some DTM (Direct To Metal) it always a good idea to protect the steel using a primer. the best system are zinc rich primer, an intermediate epoxy and finish coat is a urethane. There's aromatic an aliphatic urethane you can use. In civil structure, you will choose your system accordingly to the type of environment it will be. A good example would be using ISO 12944 standard:
ISO 12944-2 Classification of Environments
Covers the corrosivity of various environments and how these can be measured. Various anti-corrosive systems can then be specified for these environments.
ISO 12944-3 Design Considerations
Deals with best practices in structural steel design from a corrosion prevention viewpoint.
ISO 12944-4 Types of surface and surface preparation
Covers surface preparation - reference to ISO 8501, IS0 8502, IS0 8503, and ISO 8504.
ISO 12944-5 Protective paint systems
Typical paint systems by generic type for a given durability in a given environment.
There is 8 parts which are not necessary fo this discussion... unless you want to know more about!
Register to Reply 2 comments
