Previous in Forum: air craft   Next in Forum: car radio unlock code for a vauxhall astra
FG Wilson Diesel Generating Set
02/23/2009 3:42 AM
Dear all,
Would u please advice me what is the easiest way to check the alternator and Engine coupling alignment checking? I have 400KVA, canopied FG Wilson Diesel generating set. This genset is dropped down at un loading period. I found that the engine and alternator base frame is bended, engine and alternator bracket is bended, engine oi sump also cracked. I don't have any alignment checking tools. Please advice how I can start the work to solve this problem.
Thanks
Hanif
Re: How I can check Aleignment the alternator and Engine coupling
02/23/2009 4:05 AM
Try this post.
Regards JD.
Good Answers: 103
02/23/2009 5:21 AM
Please check up the condition of equipments since the amount of damage is serious and 400KVA is a large enough equipment. You do not want to start the machine and let everything fall apart. Alignment is always the end operation. Also remember in these machines external non-damage do not mean it is OK.
02/23/2009 6:04 AM
Thanks for your avdice. Would u pls tell me how I can start my disassembling and assembling work?
Good Answers: 103
02/23/2009 7:43 AM
This is where you will get us stumped.
If it is new one why don't you contact the OEM for advise ? they will gladly come over and check it up for a few $s. Other option is their service man/ dealer.
Easy on your pocket if it is insured.
But knowing the health may save a quite few times money than allowing it to go on.
Anyway post the makes etc, some of us may be able to help you out.
Good Answers: 123
02/23/2009 5:31 PM
Welcome to the insanity. Try this site. They are about generators and old engines. Good luck. http://www.smokstak.com/forum/showthread.php?t=36264
Bob
Re: FG Wilson Diesel Generating Set
03/11/2009 9:22 PM
Would be tough work for you, if the frame is bent and the Oil sump is cracked. The chances of internal damage are high. suggest contact the company themselves.
03/15/2009 5:40 AM
if frame bent & sump cracked then it would be safe bet to salvage parts & make new frame. have insurance on same?
Anonymous Poster (2); bob c (1); engrabuhanif (1); jdretired (1); sb (2)
