Previous in Forum: Reciprocating Compressor   Next in Forum: Farmer's Well - GPM Output
8 comments
Antifriction Bearings
02/23/2009 7:16 AM
What do the digits on bearings mean,e.g 6307 zz and how can I go about selecting bearings for different uses?
Good Answers: 103
Re: Antifriction Bearings
02/23/2009 8:58 AM
you are talking about ball bearings
each digit of the bearing number has a significance and usually follows a standard (ABMA for US and DIN/ISO for european)
eg for your case refer
http://www.gizmology.net/bearings.htm
However selecting of the bearing is a bit complex factor.
You have to know the shaft (ie bearing bore size)
then the static and dynamic rating, L10 Life and based on that you select the standard bearings
go to any of the bearing sites
www.skf.com
www.fag.com
www.nsk.com
etc and select the bearing. Accordingly design the housing and proceed.
02/23/2009 12:46 PM
6307 zz or 6307 2z ?
In SKF:
63 is Single row, Deep groove ball bearings (first one or two digits refers the type of bearing)
07 stands for 35mm (last two digits, here 07 multiplied by 5 would give the inner diameter of inner race. To this diameter of the shaft a bearing is required for).
2z stands for shield on both sides (the shields to prevent dust and to contain grease)
02/24/2009 1:33 AM
Just a point on the 5x rule for the bore size, it only works from 04 numbers and upwards, below that 01 =12mm, 02 = 15mm and 03 = 17mm (not too many to remember).
This method of establishing bore size works for general catalogue bearings, other types like needle roller bearings and imperial bearings follow different rules.
Steve
Good Answers: 68
02/24/2009 6:27 AM
Hello cool moody,
Here is some sites that might help:
Good Answers: 68
02/24/2009 6:56 AM
Hello cool moody,
I searched for "bearing nomenclature" and found this site.
This explains what the numbers mean and further down the page is the meaning of the various letters, as in your case 'zz'.
I know this will answer the first part of your question. And other drawings and explanations on this site may help with the "how can I go about selecting bearings for different uses"?
Bearing Nomenclature
You can learn a lot about a bearing just from its part number.
A typical bearing is the 6203ZZ bearing. This part number can be divided into it's components:
6, Type code
2, Series
0, Bore
3, Suffix
ZZ, Double Shielded........... (Z, would be single shielded).
which means:
  • Type Code
  • Series
  • Bore
  • Suffix
The type code indicates the type of bearing. While each manufacturer uses their own numbers, there are a few numbers that could be considered standard in the industry.
If there is no fourth digit - for example, a 608 bearing, a common roller skate bearing - then the size is the last digit in millimeters.
The last letters indicate something special about the bearing. For example:
ZSingle shielded
ZZDouble shielded
RSSingle sealed
2RSDouble sealed
VSingle non-contact seal
VVDouble non-contact seal
DDUDouble contact seals
NRSnap ring and groove
MBrass cage
This will answer at least some of your questions.
Take care and good luck.................
Good Answers: 103
02/24/2009 7:17 AM
IPR violation see #2
Good Answers: 68
02/24/2009 7:34 AM
06/11/2010 11:42 AM
There are not only ZZ but some other letters & numbers . What do they mean? can some body explain Please? typical example of such number is as follows. 6307ZZC3GJN, What does C3GJN mean please?
Register to Reply 8 comments
babybear (3); psrupasinghe (1); sb (2); simplybearings (1); yesyen (1)
