Previous in Forum: Red Lion Controls CL20 - Image File Needed   Next in Forum: Electronic Medical Record (EMR) Software
Excel Formulas
02/24/2009 4:23 AM
Hi,
Kindly educate me on how to use excel formula to compute the following as per the table shown below.
1. The Alarm Duration (cell: H2) which is the difference of Alarm End Date/Time (Cell: G2) and Alarm Start Date/Time (Cell:F2). The Date/Time format is MM/DD/YY, Hour:Min
2. The Percentage Outage per day (Cell:J2) ie Daily Alarm Duration (Cell:H2) in Seconds divide by (24 x 60 x 60) x 100%
1
A
B
C
Date
E
F
G
H
I
J
K
L
2Site IDSite AdressRegionDateAlarm statusAlarm Start Date and Time (Date, Hours:Min)Alarm End Date and Time (Date, Hours:Min)Alarm Duration (Hours:Min)Remarks% outage per day% power unavailabilty per week% power availability per week
Thanks as you assist.
One good Thing deserves Another
New Zealand - Member - Member Australia - Member - Member
Good Answers: 43
Re: Excel Formulas
02/24/2009 5:52 AM
Hi EnB,
Was that you as Guest earlier with identical question? I am sure you will have improved responses now you have shown your registration.
For your time data entry cells F2 & G2, Format as Time HH:MM:SS. The time duration difference H2 is simply cell formula; =sum(G2-F2). Format cell H2 the same as cells F2 & G2.
The % per day, cell J2, is; =sum(H2/24) with the cell formatted as Percentage. i.e. Menu Format/Cell/Number/Percentage.
Re: Excel Formulas
02/24/2009 8:53 AM
Hi AussieBob,
Your hint will work when the two events happened on same date. Am looking at a scenario where the two events happened on different dates. Let say the Start date&time is 22/02/2009 10:25:45 and the end date&time is 24/02/2009 11:03:22.
I want the Equation to return the difference of the two events in minutes or seconds.
Thanks for the assistance.
Good Answers: 74
Re: Excel Formulas
02/24/2009 6:59 PM
Date A - Date B gives the difference in days.
Time A - Time B gives the time difference in a fraction of a day (can be negative).
Date A - Date B + Time A - Time B gives difference in days. Store in general format.
For difference in hours, multiply by 24.
For difference in minutes, multiply by 24*60.
For difference in seconds, multiply by 24*3600.
Bruce
Popular Science - Biology - life lover Hobbies - Musician - music lover Safety - Hazmat - better safe than sorry United Arab Emirates - Member - desert trek Technical Fields - Procurement - procurement
Good Answers: 58
Re: Excel Formulas
02/25/2009 2:29 AM
Hi EnB,
Here's a step-by-step, how-to-do-it:
1. Click on Cell H2.
2. Type everything inside the quotes: "=(G2-F2)". Press Enter.
3. Right Click on Cell H2 again, and format the cell to your desired format.
4. Click on Cell J2.
5. Type "=(H2/(24*60*60))*100" and press Enter.
DONE! You can simply copy the cell to the rest of the cells below it in the column to calculate the other values you may have in the rows beneath.
Hope that helps.
Now the darkness only stays the night-time, in the morning it will fade away. -- George Harrison (All Things Must Pass)
Re: Excel Formulas
02/25/2009 4:52 AM
AussieBob (1); ba/ael (1); EnB (1); langyaw (1); Randall (1)
