Previous in Forum: Inspecting a Heat Exchanger with a Portable, Flexible Boroscope   Next in Forum: seminar topic
Wanted: Gear Box with Low Horsepower and High Gear Ratio
02/25/2009 1:50 PM
Im looking for a gear box that will provide a 30:1 ratio while having an incredibly small input horsepower (1/25-1/30). Does anyone know any vendors where I may be able to find these around New England?
Re: Low horsepower, high gear ratio gear box
02/25/2009 2:25 PM
You need to define 'small' and 'incredibly small'
this sort of gearbox comes in high ratios.
Many manufacturers do similar designs.
Or is this too small?
One man's 'small' is another man's 'Big'
02/25/2009 4:40 PM
These links are great!, the 1:30 ratio and size are exactly what im looking for with such low horsepower. Although, I made have made a mistake. I am looking for vendors in New England, as in the North Eastern United States.
02/25/2009 5:48 PM
Try a search for 'oviod gearbox' I think that's the term for that sort of gearbox.
Good Answers: 103
Re: Wanted: Gear Box with Low Horsepower and High Gear Ratio
02/25/2009 8:57 PM
Or Worms (if it is at 90 degress transmission).
Planetary gear boxes maje be good for 180 deg transmission (either single or double)
on google http://www.google.co.in/search?hl=en&q=planetary%2Bratio%2B30&meta=
third entry is
Planetary gear drive On GlobalSpec
LP090M0230111001, PLC Radwell, ALPHA GEAR DRIVES, Not Provided, GEARBOX PLANETARY RATIO 30:1. TP010MF221021000, PLC Radwell, ALPHA GEAR DRIVES, Not Provided ...
motion-controls.globalspec.com/Industrial-Directory/planetary_gear_drive - 87k -
using globalspec search engine you may find your needs
02/25/2009 11:56 PM
Have you checked with your nearest electronic surplus dealer? They have stuff fitting that description most of the time in ours... mostly in the $3-10$ range, some higher.
Belgium - Member - New Member
Good Answers: 21
02/26/2009 5:39 AM
take a look at the compagny maxon motor
maxonmotor.com
output shaft diameter as small as 2 mm
input power as low as 0.75 Watt
Hobbies - CNC - New Member Hobbies - Musician - New Member
02/26/2009 7:09 AM
Sounds like your local hobby shop might do the trick (model trains, cars, planes, helicopters). Otherwise RS electronics has a fairly wide range.
Think and move like an electron
Register to Reply 7 comments
croderick751 (1); dkwarner (1); madness (1); rudy.leurs (1); sb (1); user-deleted-1105 (2)
