I need to calculate the stress on a circular plate due to an eccentric load. I have a pipe coming up from the top of a tank, making a 90 degree bend, and an actuator is attached to the pipe 38" away from the pipe/tank connection. This generates a moment of approximately 19,000 inch-lbs (500# weightx38").
Additional Information:
Diameter = 144"
Edges fixed
Distance from edge of tank to centerline of pipe = 10"
Therefore, I have a 19,000 in.-lb moment applied to a circular plate 10" from the edge of the plate
I went through Roark and found Table 24, Case #21, but I believe this is for a moment applied at the center of a plate, not near the edge. Does anyone know if my interpretation of Roark is correct, and if so, how to calculate the stress on the plate from this type of load at this location?
All feedback welcome, including "I don't know".
Thank you in advance.
