Previous in Forum: Fabricating Pipe Fittings   Next in Forum: Open-Die Forging
Good Answers: 266
CNC Turret Press
02/27/2009 8:30 AM
My company is looking in to fabrication curtain wall. The reinforcement is rectangular steel tube. The largest that I have seen in this application is approximately 2 1/2 X 4 inches with 1/16 wall. That does not mean it will not change so a bed that is 12" wide should do. This tube in the USA come in 24 foot lengths. Most of what I have been able to come up with on these type presses are for flat sheet.
Does anyone know of companies that produce a CNC Turret Press that would process long lengths of tube. Also would like recommendation for a production saw to cut the steel tube.
Re: CNC Turret Press
02/27/2009 1:27 PM
Behringer makes a good saw. We use ours regularly for flat stock, shaft stock, angle, channel and round and square tubing.
As far as the press, you could try Dayton Rogers.
CARPE CRUSTULORUM!
02/28/2009 7:25 AM
Have you considered metal studs?They are available in many dimensions,usually corresponding to lumber sizes, and in many gauges,depending on whether load bearing of not.
"I See" said the carpenter as he picked up his hammer and saw.
Good Answers: 68
02/28/2009 8:50 PM
Hello ozzb,
how are you?
You may find some of this helpful? Have you thought about a laser cutter, rather than a saw? I am sorry I forget his name now, but the saw that a previous poster pasted looks pretty good. It really depends on how long you will need one and where you could hire one. But the press may have a means of cutting attached already?
CNC punch press eliminates drilled holes: News from LVD (UK)
1 Aug 2002 ... The installation of the latest CNC turret punch press has allowed holes to be accurately punched out in process, rather than drilled on assembly. ... which was not really practical before due to the length of set-up and capability of the machinery. ... Tube bender helps BAE systems build sub ...
www.manufacturingtalk.com/news/lvd/lvd127.html - 28k - Cached - Similar pages -
Sheet metal tube bending and shaping
CNC Tube Bending is ideal for parts containing more than two bends. To start the bending process, the operator feeds cut-to-length material into the ...
www.daytonrogers.com/tubebending.aspx - 26k - Cached - Similar pages -
GPBrochure LVD 2008:LVD GENERAL PROSPECT ENG
or channels, pre-formed parts and tubes. Available in table sizes up to 3mx12m with ... in configurations up to 3000 tons and 18 meter working lengths. PPEB Series. Precision PC-based ... A robot coupled with a CNC turret punch press ... streamlines the fabricating process by providing a complete programming system ...
www.lvdgroup.com/files/items/633512835779258750.pdf - Similar pages -
[FLASH]
Fabrication Division of Chief Industries, Inc. Designed and ...
File Format: Shockwave Flash
... system will also assist in the logistics/inventory control process. ... Thickness 5/8 CINCINNATI SHEAR Length 8 cut Max, Thickness 1/2 WYSONG SHEAR Length ... Station WIEDEMANN W4560 CNC TURRET PUNCH WITH PLASMA Tonnage 45 Capacity 3/8 x ... WALLACE TUBE BENDER, 3 110 TON PRESS BRAKE Hydraulic (Promocam) Bed 12 ...
www.chieffabrication.com/cfd_website.swf - Similar pages -
Take care....................
Register to Reply 3 comments
babybear (1); not so smart (1); ShoeShineBoy (1)
