Previous in Forum: Post Office quietly removes all vending machines.   Next in Forum: Flushing
SLow loss of Gain in Set Top Box
02/28/2009 6:24 AM
My Set Top Box has slowly lost RF gain so the signal has become "unreliable" - a new Set Top Box fixes the problem so it is not the antenna - what component can slowly fail like this?
I have several Set Top Boxes - all made in China - which exhibit this same fault - slowly loosing RF gain - what component can fail in this way over about one year?
How to fix this problem?
Of course they just last long enough to be outside the 1Year Warranty period.
Re: SLow loss of Gain in Set Top Box
02/28/2009 6:50 AM
Most likely cause is connections....
Where the connector is soldered to the pcb.
Not much you cac do other than re-flow all the joints...
Trying to faultfind anything like that is impossible unless you work in an RF lab* and practice those Dark Arts of which I shall not speak.
*Or you are a radio ham with a shed ful of kit.
02/28/2009 5:31 PM
Dear Del,
Assuming one has some inkling into the Dark Arts, into what in particular would one begin to delve?
Would there be a specification sheet which one could peruse?
Maybe a drop in voltage somewhere that one could check or observe?
These tuners come as a package - what would be involved in changing a tuner? - can replacement tuners be obtained?
02/28/2009 5:36 PM
I'm the wrong cat...I hate RF with a Passion...sorry.
03/01/2009 12:11 PM
Many set top boxes run very hot. I had to return one once because I was afraid it would set my shelves on fire!
Such heat will cause an RF amp to degrade over time. You might try adding a heat sink to the input RF amp.
Re: Slow loss of Gain in Set Top Box
03/02/2009 3:21 AM
Disclaimer: I know nothing about RF but:-
Are there any aluminium electrolytics (metal canned capacitors) in the design, they dry out over time especially if they are running hot, so in combination with with
WoodwardDL's answer at #4 this might be a problem.
For quick and dirty calculations cheap electrolytics are often spec.'d at 2000 hrs. at 85ºC. Their life improves two fold for each 10º C lower you run them, so you'd expect them to last about a year at 55ºC two years at 45ºC etc.
I don't think I'd expect to find them anywhere in the signal path but if they're being used to smooth a power supply rail they might still produce the effect being seen.
cirreb217 (1); Randall (1); user-deleted-1105 (2); WoodwardDL (1)
