Dear Sir,
I am approaching you for your expert technical advice on following problem :
A 60 in diameter 14.75 mm thick carbon steel pipeline externally coated with polyeurythene and internally coated with cement lining approx 1 inch thick is used for transporting potable water at pressure of 40 bars.
At places cement lining is fallen off and getting accumulated thus obstructing smooth flow.
In order to remove this concrete debris the pipeline is cut and cleaned.
To determine location spots of debris collection flow rate meaurements are carried out but sometimes no debris is found.
We tried to ascertain location by using RT at these suspected points. Initial RT using films, we did not get any result as exposure times extended upto 10 hours using Ir-192 of 80 Ci. The films were found to be absolutely blank. We covered 1/4 th of a pipe at a time.
We tried direct measurement of radiation through pipe by placing source at one side and dosimeter at opposite end ( 180 degree opposite ) and measured dose for 3 minutes. Such 20 readings were taken all around pipe. But there was neither uniformity nor co-relationship in reading to come to any conclusion. On cutting the pipeline accumulated cement was found.
Sir, is there any suitable RT technique to confirm or ascertain location of concrete debris where water is flowing ?
In case any other information is required on the subject to evolve new technique, please do let me know, I shall try and provide you.
Best Regards.
Vijay Vesvikar.
