Previous in Forum: license agreement   Next in Forum: The Cost of Sheet Metal Components
Welding Defects: What is Burn-Through?
03/03/2009 8:17 PM
What is the meaning for "BURN THROUGH" problem in the welding defect.How is it happen?.What solution?
Re: Mechanical Engineering
03/03/2009 10:15 PM
If "burn through" is a problem, you must have a document that defines this quality, otherwise it would not be a "defect". If you have a document for defects, you may have one for process control, and one which gives a solution.
You may not have any of these, so, stop the welding process prior to exiting the bottom plane of the material being welded.
Good Answers: 51
03/03/2009 11:54 PM
"Burn through" is exactly as it sounds. You melt through the metal you are trying to weld and create a big unsightly hole/gap - particularly troublesome with sheet metal / thin plates. It is generally a result of too much penetration caused by having too much heat input in the weld zone. You can correct this problem, with MIG, by reducing the wire-feed speed, which, in turn lowers the welding amperage. Also you can increase the travel speed. Burn-through can also result from having an excessive amount of root opening. To correct this problem, you increase the wire stick-out and oscillate the torch slightly.
What process are you using? MIG, spot, TIG, .............?
Does these articles help?:
http://www.millerwelds.com/education/articles/article101.html
http://www.thefabricator.com/ArcWelding/ArcWelding_Article.cfm?ID=2003
A little knowledge is a dangerous thing.
Popular Science - Biology - life lover Hobbies - Musician - music lover Safety - Hazmat - better safe than sorry United Arab Emirates - Member - desert trek Technical Fields - Procurement - procurement
Good Answers: 58
03/12/2009 7:48 AM
that deserves a GA.
Guest, here's a pic that can help you differentiate between good and bad welding. the one at the far right leads to burn through.
and here's how a burn through looks like at the opposite side:
Now the darkness only stays the night-time, in the morning it will fade away. -- George Harrison (All Things Must Pass)
langyaw (1); lyn (1); XMech (1)
