Previous in Forum: Control Valve / Flow Meter   Next in Forum: Motor Control and Run Dry Protection for a Pump
AS-500 ABB Operator Station for AC450 Controller
03/05/2009 3:48 AM
Hello Guys,
I am using AS500 Operator Station which runs on HP Unix 10.2 and ABB's Advacommand 1.8/2. This OS was previously getting hanged up frequently, so it was reloaded with original software form DAT Tape. It has been connected to AC450 Controller through Advant Fieldbus on its network along with other two similar OS used by Plant Operators. It also has TCP/IP network for connecting it to other OS. After reloading the software, now it does detect the host controller AC450. Also it is not being detected by other nodes in network. While installing the software there was no alarm message, no errors were shown. Now it is starting up properly. As there is no connection to host controller, this OS does not display the process data. Can anyone have idea what may be the reason? How to trace the fault?
Waiting for positive thoughts....
Best Regards, srzambre.
Pathfinder Tags: ABB AC 450
South Africa - Member -
Good Answers: 12
Re: AS-500 ABB Operator Station for AC450 Controller
03/05/2009 7:40 AM
Hi there,
Does the original software support the AC450? Do you perhaps need to install an additional patch/driver or something of the like?
Perhaps you should have a look at the ABB site or contact them?
Regards,
Craig
09/16/2009 4:38 AM
Do a cold restart on operator station. Option is selectable by keys at bottom of screen in AdvaCommand
Register to Reply 2 comments
