This is probably a very simple question to a vibration expert, but I haven't worked with this in many years...
I have been asked to build a shaker for a product we make for fatigue testing of internal (electrical) components. We basically have a budget for buying a couple vibrators off the shelf and welding a frame of some sorts. The product is Ø1.875" x ~9'L (tube shape) and weighs a total of about 68 lbs. The target vibration level is 5-10G shock.
I want to buy a shaker from McMaster (maybe several) and build a bracket to connect it to the tool. The vibrators are qualified by force in lbs and vibrations per minute. How do you size the vibrator and how heavy does the mounting block need to be to get 5-10G vibration onto the tool? what about noise? how would you mount the setup in the shop?
The goal is to catch any poorly soldered connections, broken wires, loose parts, etc. before shipping it out. Do you have any other recommendations for a shaker for this purpose?
