Previous in Forum: ASTM Designations   Next in Forum: Wire / Rope for Spreader Bar
ASTM Grades of Steel
03/06/2009 2:42 AM
what different grade means?
e.g.,A672 Gr.A45,A672 Gr.A50,A672 Gr.A55,A672 Gr.C55
what does these alphabets Gr.A,Gr.B,Gr.C means?
from where comes these values 50,55,60?
Good Answers: 51
Re: ASTM Grades of Steel
03/06/2009 8:25 PM
A672 is a specification that covers steel pipe (electric-fusion welded with filler metal added), fabricated from pressure-vessel quality plate of any of several analyses and strength levels suitable for high-pressure service at moderate temperature.
I have posted the table from the standard identifying the pipe grades of A672 to which plate material it was formed from:
The additional numbers and letters (A, B, C,......... 50, 55, 60, ..........) identify different grades within a specification based on composition, properties, and strength.
The numbers generally correlate to minimum specified tensile strength.
A little knowledge is a dangerous thing.
03/08/2009 10:37 AM
thanks for ur answer.may i know which book is this and from where i will get it?
Good Answers: 51
03/08/2009 3:11 PM
That came directly from the standard, available for purchase here:
http://www.astm.org/Standards/A672.htm
05/10/2009 2:27 AM
Is A672-A55 can be used on a pipeline designed using ASME B31.3. service fluid is ethylene and operating pressure is 46 bar and temp is 55C.
Good Answers: 51
05/10/2009 1:05 PM
Yes, A672-A55 is allowed with B31.3
07/28/2010 10:07 AM
What is the equivalent of s355 in astm
Register to Reply 6 comments
Anonymous Poster (2); milindjoghari (1); XMech (3)
