Previous in Forum: Injection Molding - Tubular Design   Next in Forum: Power Arc Plasma Cutter
Abrasion Test on UV Coated Surface
03/06/2009 9:48 AM
I am working on plastic coating industry for telecommunication device ( mobile phone and bluetooth headset), as most of the product from this segment are go through surface decoration process such as painting,printing, Vacuum metallization or electroplating to achieve the finishing requirement.
these device are getting smaller in size and end user trend to put them in pocket, when contact with cloths, abrasion and wearing of coating happened where causing the paint wore off and explored the bare plastic....
recently I am working on this matter and looking for UV paint that can withstand 100 cycle of abrasive testing by using Normal tool Abrasion tester model 7-1BB), the testing requirement as following:
1) arm weight: 176g;
2) Abrasive tape : 11/16" wide paper strip from Normal tool inc.
3) Criteria : No substrate visible after 100 cycle.
any suggestion and comment are welcome.
Thank you
Regards,
Surface
Re: Abrasion Test on UV Coated Surface
03/08/2009 9:33 AM
Why not just use plastics that have UV resistant additives already compounded in? Then you don't have to worry about coatings that can wear off. UV resistant acetal products from www.Ticona.com are commonly used for automotive, telecom and other applications exposed to the sun or other UV sources.
03/09/2009 8:32 PM
Thank you for your suggestion. the reason not using direct UV additives is for surface decoration purpose.
Register to Reply 2 comments
You might be interested in: UV Filters
