Hi folks,
I hope someone can lead me in the right direction. I have a 1.5 HP delta motor, it's off an old drill press. The motor was missing the start capacitor and the run capacitor only had one lead connected to it. I did find out the start capacitor size but now need to hook up both capacitors. There are 3 wires for each capacitor. One of the the wires is a jumper that crossed between the two capacitors. The wires labeled for the run; T5, T9, and T7 is the jumper. For the start T5, T6 and T7 for the jumper. I have found that the T5 leads for the start and the run cap must be across a winding as the resistance is 2.3 ohms. The T5 lead on the start side is connected to the white feeder wire on the 240 volt in to the motor which is also tied together with the T4 lead. I figure the T7 jumper wire is likely tied in to the T5 wire on the start capacitor side of the motor and connected to the run side but opposite of the T5 lead. I did check resistance across all of the terminals and will list them if someone thinks they can figure this out that way. I would pull the back cover off to see where the leads go but there is a plastic fan there and I am affraid it will self destruct if I attempted to remove it.
