We do not do that. We specifiy valve types, trim, etc etc as well as needed calculations - to physically design from scratch would require the valve manufacturer. Have a look at the book I mentioned - otherwise you should try to get hold of a mechanical engineer.
Prepare Datasheet From the PFD Process flow diagram , give to procurement let them float the enquiry , Vendor will size and give the the correct valve Capacity & Actuator Size , evaluate for the following (noise , velocity,Material of construction ) using ISA 75 series .API 553 other relevant standards
