Previous in Forum: cadworx plant and P&ID   Next in Forum: why voltage rating in india are in multifling factor of 11 kv
Earthed or Unearthed Cables?
03/12/2009 1:27 AM
I have an 11KV DG set. The Neutral is earthed through a NGR. Which type of cable i have to select, I have to go for un earthed or earthed cables.
Re: Earthed or Unearthed Cables?
03/12/2009 2:24 PM
When you say "earthed" do you mean screened (like a coaxial cable with the screen providing an earth function), armoured (like a coaxial cable but steel (or similar) strands providing mechanical protection), or earthed (as in the three phase cable also includes an earth wire).
The answer depends on which country this site is in (and local electrical regulations and standards). I suggest you consult them first for the answer that is applicable to you, better yet as this is an industrial application ask your site electrician.
Good Answers: 42
03/13/2009 3:18 PM
This subject was discussed many times earlier in CR4 . Better read the previous threads on the subject.
http://cr4.globalspec.com/comment/318579
The selection of earthed/unearthed cable will depend on your system. If your distribution system is earthed then you have to use cable manufactured for earthed system. (which the manufacturer specifies). If the system is unearthed then you need to use cable manufactured for un earthed system.The unearthed system requires high insulation level
Hope yo get your answer..
